A friend has a Potterton Proforma 28 combi, about 10 years old. She says "there is now a loud click", and could I see what is happening. The noise is from the gas valve. I put my finger on the valve and it is the solenoid. The valve works OK just a loud click when the solenoid is activated. The click was never so loud. I told her it is working fine.
She is frightened of a breakdown leaving her without heat and hot water and would buy the part ready so that when it fails a service man can just fit it without waiting a day or so to order the part. Good thinking thought I. It is a Honeywell gas valve with a black solenoid unit on the valve. It also has a yellow modulating part on the valve. The black solenoid part looks like it can screw on and off and is replaceable as screws are either side of it. I looked on the web and cannot see this as a separate item. If it can be ordered and put next to the combi in case of failure that would be ideal.
The questions are:
1. Is this louder click an indication it is about to fail?
2. Is the solenoid part available as a separate item?
The questions are:
