Hello all,
My 2 year old Suprima 40 boiler isn't heating properly
, it seems to only heat water to about 60 C even when the thermostat is turned to maximum. The boiler is feeding a vented system comprising 11 radiators plus hot water tank.
Thanks to this board I'm aware that this model of boiler has known issues with the control board PCB and dry joints. I've checked mine and can't see any obvious dry joints so I suspect that the problem is one of the following:
1. Temperature sensor/thermocouple faulty.
2. Dry joints that aren't obviously visible.
3. Other control board fault.
Does this sound like the a faulty temperature sensor or yet another PCB fault? I'd very much appreciate some advice before parting with any money.
Thanks.
Thanks.
