- Joined
- 11 Jan 2004
- Messages
- 60
- Reaction score
- 0
- Country
I have a Potterton Suprima 40 boiler in a standard setup. I have this problem whereby every day or two, the boiler will randomly turn off and flash it's red LED which means it's overheated. During this time, the pump is left on and the boiler won't fire again until I open the front cover and press the reset button.
What might be causing this? I've tried adjusting the thermostat temperature on the boiler but it doesn't seem to make any difference. Sometimes the boiler overheats when all the radiators still seem to be cold.
The pump appears to be working OK but does make a funny clicking noise if you turn it up to full speed, but is definitely pumping water because you can hear it running round the rest of the system.
Any ideas what might be causing this problem? Potterton want £245 to come out and fix any problem (including parts) and warned me that some parts cost £200 anyway. It seems very expensive bearing in mind I don't yet know what the problem is. What should I do?
Nick...
Nick...
