Potterton Suprima 80 intermittant lockout
3 Oct 2003
Seems to be a common problem with Suprima range. Mine sometimes has a lockout out on initial startup - red light flashing and no ignition. Pressing reset usually gets it going straightaway but next time it can happen again. Other times no problem. Can't be overheat, is it PCB ? :confused:
I would say YES They all seem to give up after a few years.
Potterton introduced a improved pcb about two years ago.
If you do search for 'potterton suprima' you will see others with the same problem.
I think the pcbs are common in the 30 to 70 range the 80 may have a different pc board.
:rolleyes: :rolleyes: :rolleyes:
Thanks for that, Mandate. I've looked up other cases and found similarities..looks like pcb is chief suspect alright. Maybe reflow the solders, otherwise replacement part at 226 euro incl. VAT.. :eek: ouch! At least I can refit it myself and save the call out charge. There's a new version pcb p/n 5102160 which replaces p/n 407750 so Potterton must have realised that there was a problem with the old part. Thanks again for your help.
Or you can get cheaper re-con ones from http://www.cetltd.com/ much cheaper. But it sounds like you have the same problem i had, you just need to reflow the majority of the solder joints, it worked for me, good luck :)
AL
