I am having a problem with our heating system. Everything is working as expected except that the pump is not being run. Therefore boiler (Suprima 80L) quickly and correctly cuts out. Pump appears to be free but I cannot detect any power to the pump. System is four years old Y plan configuration and Grundfos 15/50 pump. Have therefore come to the initial conclusion that the boiler PCB (almostly certainly 8407750) has partially failed. Do the experts believe I am on the right track or should I try something else before calling a Potterton engineer. Any advice gratefully received. I understand the later 5111603 PCB is much more reliable.
