I have just had to replace both taps on an upstairs radiator due to them seizing. I therefore had to drain the water out of the radiator & I assume the rest of the system upstairs.
I have a powermax 155, which has a header tank. I turned the inlet to this tank off when I was draining the system. I have fitted the new taps to the radiator & turned on the inlet to the header tank - it filled up & I bled the radiator. However, the boiler will now not light. Electric & gas are all available etc.
Is there air in the boiler? If so I cannot find anywhere to bleed the air out.
Andy
Andy
