pps attachments have stopped opening automatically
Discussion in 'Software' started by dolph, 23 Sep 2008.
  1. dolph
    dolph
    16 Mar 2004
    136
    Thanks Received:
    Country:
    I have always been able to open .pps files in email attachments but all of a sudden when I double click the attachment I now get the message come up "This file does not have a program associated with it for performing this action. Create an association in the Folder Options control panel"
    I can right click attachment, save the .pps file to desktop, then open it through Microsoft Power Point.
    In the control panel PPS is shown to be active so I am at a loss to understand why the double clicking on the attachment has stopped working?
    I have tried to restore the computer using restore function to before problem started but it will not restore to highlighted restore point selected.
    Any one any ideas or suggestions please.
  2. Sponsored Links
  3. dolph
    dolph
    16 Mar 2004
    136
    Thanks Received:
    Country:
    I managed to correct by downloading a new Microsoft Powerpoint Viewer file from microsoft and attaching this through Control Panel as per http://windowsxp.mvps.org/ppsopen.htm. Obviously my original file had corrupted itself somehow!
    Still cant understand why I cannot restore to a restore point any ideas please
  4. HectorTheSpecta
    HectorTheSpecta
    1 Jan 2008
    34
    Thanks Received:
    Essex
    Country:
    You could've right click on the file in explorer select 'open with'. When Open with dialogue opens select the program you want to open with - in your case Power Point from the list. If not available browse for it. Make sure you check 'Always use the selected....'
    For your second problem it would seem your restore options are probably turned off and 'slimmed' down.
    Right click on 'My Computer', click on Properties and click on the tab 'System Restore' and check your options, particularly under settings.
  5. 2scoops0406
    2scoops0406
    20 Jan 2004
    4,865
    Thanks Received:
    2
    Buckinghamshire
    Country:
    Shouldn't they be .ppt files?
  6. MarkBarl
    MarkBarl
    7 Sep 2007
    497
    Thanks Received:
    11
    Hampshire
    Country:
    PPS is Power Point Show. It open up straight into the show.
  7. 2scoops0406
    2scoops0406
    20 Jan 2004
    4,865
    Thanks Received:
    2
    Buckinghamshire
    Country:
    Fair enough, just a case of re making the file association then?
  8. Sponsored Links
Loading...
Share This Page
