    Dismiss Notice
Pre-fabricated Flues ok for wood burners?
Discussion in 'Plumbing and Central Heating' started by Brooker, 8 Dec 2012.
  1. Brooker
    Brooker
    20 May 2010
    12
    Thanks Received:
    Cardiff
    Country:
    I have an old boiler that we no longer use, it has a Pre-fabricated Flue which is 15cm diameter:
    [​IMG]
    Is it possible to remove this boiler and install a wood burner? This is a basement room so it is concrete underneath the carpet - wall directly ahead is an outside wall.
    If so would it be a relatively inexpensive fit? Any idea on costs?
    I guess an open grate - a fire basket, is totally out of the question?
    There is a lot of woodland around here so a fire would be quite nice - especially with rising fuel costs. Any thoughts or advice appreciated. And if any of you can install one in South Wales please let me know.
  2. Sponsored Links
  3. swbjackson
    swbjackson
    12 Dec 2008
    1,684
    Thanks Received:
    151
    Sussex
    Country:
    It depends on the type of prefab flue. Your best bet is to get a HETAS registered engineer in to advise you.
  4. Corgigrouch
    Corgigrouch
    13 Dec 2007
    4,009
    Thanks Received:
    512
    Country:
    These days open fires need MASSIVE vents in the wall so not really worth while... Usually the prefab flues will be something like Selkirk IL and that would be a definate no for solid fuel.... Yor HETAS installer is the man to ask.
  5. Brooker
    Brooker
    20 May 2010
    12
    Thanks Received:
    Cardiff
    Country:
    Thanks for the replies.
    Swbjackson - does this photo help regarding the flue?
    [​IMG]
    Corgigrouch - there is already quite a big vent behind the boiler, though I did spray some foam filler in it when we installed a new boiler as it was too drafty! lol
    I'm interested in the cheapest option tbh - this is a basement room so it doesn't have to be anything special, just something to help heat this floor - we get loads of wood here anyway and have several bonfires a year, so it just makes sense to use that wood.
  6. Sponsored Links
  7. tamz
    tamz
    25 Feb 2009
    1,884
    Thanks Received:
    278
    West Lothian
    Country:
    Your existing flue is NOT suitable for solid fuel.
    Fitting a stove is not a cheap option. You should speak to a suitably qualified Hetas Engineer.
  8. FiremanT
    FiremanT
    16 Jan 2012
    9,249
    Thanks Received:
    1,837
    Uk
    Country:
    Tamz is correct. Think thousands rather than hundreds. Gas is probaby the best option. Have you got the time and space to prepare, store and dry "free" wood?
  9. petertheplumber12
    petertheplumber12
    5 Dec 2012
    694
    Thanks Received:
    96
    Surrey
    Country:
    And storing wood has the additional problem of introducing wood worm into the premises.
  10. Brooker
    Brooker
    20 May 2010
    12
    Thanks Received:
    Cardiff
    Country:
    Thanks for the replies everyone.
    We have a lot of laylandii and end up having a couple of bonfires a year, and also have an unused concrete workshop that would be great for storage. If that wasn't enough... one of our neighbours actually sells wood for home fires (he gets lorry loads delivered) so things were just screaming out for one :LOL:
    However if it's going to be a costly job then I think the money would be better spent on other things.
    Thank you all for you help.
  11. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
