hello all.
im looking at buying one of those range styled cookers belling country 100 df or alternatively newhomes.
both are 8 ring burners which will be fed via 15 mm pipe. which i hope is suitable and ask you guys to confirm pipe size needed.
mtr is 22 pipe located in hallway in which tee to 15 to cooker and remains 22 to loft where boiler is located.
the amount of 15mm is approx 4 to 5 mtrs in run to cooker point with guestimate of 3 elbows from the t of from the 22.
i know this is fine for normal cookers but lack experience in these big bad a** mother cough cookers as it is basically like operating two cookers at once.
installation and commissioning
once installed is the cooker commissioned in the same way as a normal sized cooker.
test three rings and thermostates plus any applicable devices such as fsd which are not on the belling cooker.
