Pressure loss not normal...need help with mystery!
14 Jan 2007
Hampshire
Blimey..whats going on here!!!
I changed the whole PRV as it is a push fit type. It is acting exactly the same as the one I changed so seems a bit coincidental but the fact both may be faulty did cross my mind.
The gauge I go by is the one on the boiler of which the red needle is just after 1.2bar
I think I found the expansion vessel today located at the rear of the boiler. I noticed a red cylinder with a pipe coming out of the bottom which lead to the PRV area and the drain plug..is this it??
However, the pipe and nut leading from the vessel was green from water corrosion by the looks of it??
I would post a picture but there is no way I'd be able to get that near...It is a Ravenheat after all
21 Oct 2004
oilman said:
If you look at manufacturers data sheets, you will find the spec is for a given flow rate at the quoted operating pressure, so it will be letting by at a lower flow rate at a lower pressure. ie could start to open at 2.5 bar.
Wow - this must now be a quorate meeting of Picky B*stards Anonymous!
It makes me so proud. :D
16 Sep 2003
Softus, is it impossible for you to post something helpful if it would agree with Agile's points? You seem only to be able to post something that contradicts or otherwise disagrees even if you are wrong. And when backed into a corner, trivia and implied ridicule seem to be your defence mechanisms.
Mr. Lil, you need to release the water pressure, and check the air pressure in the expansion vessel. (assuming you haven't done this already).
21 Oct 2004
oilman said:
Softus, is it impossible for you to post something helpful if it would agree with Agiles points?
I was making a point before Agile turned up on this topic, so I don't see the connection, unless Agile has appointed you as his agent.
You seem only to be able to post some that contradicts or otherwise disagrees even if you are wrong.
When I'm wrong I readily admit it. Always. As for being flippant, you're not keen on me being too serious either, so you're the one who's seeking out ways to disagree.
If you're claiming that PRVs have a tolerance on the rated opening pressure, then of course I'd agree.
If you're claiming that the OP's second PRV was opening within that tolerance, then I'd have to say that you were guessing, because he hasn't posted enough information for you to know that.
If you're claiming that the OP's second PRV is not faulty, I'd have to say that you were guessing, because he hasn't posted enough information for you to know that.
You're not normally given to making guesses and assumptions, so it would appear that you're being pedantic in an unsuccessful attempt to prove me wrong.
As I've noted before, you're stuck in Grudge City without a horse or a coach to get your ass outta town.
14 Jan 2007
Hampshire
Mr. Lil, you need to release the water pressure, and check the air pressure in the expansion vessel. (assuming you haven't done this already).[/quote]
Thankyou...I havent done this as unfortunately I wouldnt know where to start or how to do this
16 Sep 2003
Mr Softus, what I can say is that your statement that the PRV (original or otherwise) was faulty because it opened at less than 3 bar, was wrong. Look up Reliance data sheets, and you see that the operating pressure is quoted with an associated flow rate.
14 Jan 2007
Hampshire
16 Sep 2003
You operate the PRV so that the water pressure is zero, then you look round the expansion vessel (or feel round it) for a car tyre type valve. push the pin of the valve in momentairly and not if you get an air hiss or not. You may get water, if so expansion vessel is dead. Otherwise check air pressure with tyre gauge, and pump up to 1 bar. You need to release the water pressure so you check the air pressure only. Once the air is right, fill the water so the gauge reads 1 bar.
16 Sep 2003
Softus said:
oilman said:
Look up Reliance data sheets...
Ravenheat? :confused:
No, Reliance. That's why I didn't write Ravenheat and wrote Reliance. Reliance make the PRVs, Ravenheat only stuff the bits into a box.
21 Oct 2004
You continue to assume too much. I didn't say that you meant to write Ravenheat.
Which takes precedence - the Ravenheat MIs or the Reliance "data sheets"?
16 Sep 2003
You weren't very clear then were you. Look up the Ravenheat spec then, what does it say?
21 Oct 2004
No. I was being lazy. I apologise.
A safety valve fitted on the central heating circuit set at 43 psi (3 bar).
14 Jan 2007
Hampshire
Many thanks ...I'll see how I get on
Please continue you two :LOL:
