pressure loss on sealed system
19 Dec 2005
London
We had a new central heating system installed in July and then the system was extended by the addition of two new radiators in a new loft extension. After this point we started to experience pressure loss - we are topping up the system at least twice a day.
We've checked the radiators for leaks and there is no visible sign of a leak in the ceilings. The safety valve also seems to be OK nor does the system seem to be over-heating and water escaping through the overflow pipe. Everything seems to point towards a leak on the ground floor, but I wondered whether there are any other possibilities / avenues that we could explore.
Pipes buried in solid ground floor :?: :cry: a dose of internal leak sealer might be worth a try before you have to re- pipe :confused:
I hate to be the bringer of bad news but;
we have just gone through a similar scenario. Leak in pipes buried in concrete on ground floor (been there about 30 years), fixed but 6 months later another leak somewhere else. Only thing to do is bite the bullet and re-pipe. I've had mine done in such a way that we do not need to disturb the floor again if there is a leak i.e. all pipes are now hidden behind skirting boards. We did try leak sealer with zero success.
Sorry
Steve
Gulp. Thought it might be case. Good advice about resiting the pipes. I'll probably try the leak sealant just in case, but I'm not that hopeful.
Have you inspected the boilers heat exchanger for possible leakage. These leaks can dry very quickly when the boiler is in use (for obvious reasons).
I encountered this scenario on a Vokera Mynute System boiler that had been installed 6 months.
Long shot though
Dave
I think I am right in saying that this sealing solutions are bad news on a pressurised combi boiler system as they gum up important vents. So be aware. I'm no plumber but I do recall seeing something to this effect on these forums somewhere.
Long shot though
Dave
We checked everything but were losing all pressure in the system (1 bar -> 0 bar ) in an 8 hour period so we would have seen anything at the boiler or outside.
