Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
If pressurising a vented heating system. Will the coil for the primary flow and return of a copper cylinder take the pressure of a sealed system. Or is this a no? Thanks.
No sorry, the hot water will still be vented. Its the central heating that am looking at pressurising. So just the primary coil that am concerned about.
Yes, it may be a problem if it is a very old cylinder 25 years +. Even then it's only a possibility . The worst thing that could happen is the coil could develop a pin hole leak ,and you will need a new cylinder. The fact is no one can tell for sure one way or the other.
It's an old floor standing boiler for a wall hung one. And can't get 3meters from the top of the boiler to water level in header tank. And can't raise the header. So a strong likely hood it may pump over.
