New on here so please be patient
Ok I have removed a primatic hotwater tank from an old house because it was leaking and now have brought a new one but the new tank has more inlets/out lets than the old one !!
the system is a back boiler no radiators so its main function is to heat the hot water ... on the new tank ther is 2 one inch fittings similar spacing to a indirect tank but no coil as you can see through the tank do these fit to the boiler or the opposite side another 2 fittings same size but the spacing is closer together towards the bottom of the tank but you cant poke your fingers through do these fit to the boiler ? one of them is the bottom feed for the cold water which one ? and do I blank one of the top ones off ? the top hole is the outlet for the hot water as i know and the imersion heater .... I would like to see a diagram but to no avail cant find one !!
Please help thank you .
Ste.
Ste.
