Primatic
20 Apr 2014
I have changed my ch pump the cylinder is a primatic direct feed. The boiler wont fire up and my service engineer says it is okay and there is an airlock but he wont touch it cause i changed the pump (its political)how is the best way of getting airlocks out of this type of system. ive bled all the rads and no more air is coming out. Could there be a lock in the cylinder and how do i sort it?
By design there is an air lock in this type of cylinder. It keeps the central heating water and domestic hot water separate.
You bled the radiators, but did you also bleed the pump, boiler and other vents around your central heating system? If your boiler has an automatic air vent, check that its cap is loose enough to let air escape (they sometimes get screwed down).
change your plumber this really p******s me off when a plumber decides he is god, if he is going to get paid then what the hell get on with it just cos he couldnt charge you profit on the pump. If he thinks you may have messed up then he should explain why if he thinks its dangerous then it should be his duty to keep you safe
had a new customer the other day she wanted to change her bath taps she called her plumber who said he could do it that week until he found out she had bought the taps then all of a sudden he was booked for a month.
I went there changed the taps £40.00 thanks very much
