Problem ceiling
4 Mar 2006
Preparing my parents' kitchen prior to having a new kitchen fitted in a few weeks. Managed to get the artex off the ceiling (that and lots of grease and nicotine ...bleurgh). Ceiling isn't too bad, just a few lumps and bumps which I thought I'd cover with Polycell Crack Free Ceiling (had some left over from my kitchen).
Put the first coat on the other night and went back to put another one and noticed a raised patch...touched it and it basically had 'blown'. I think I'll have to try and strip it off/sand it down and start again.
Can anyone suggest some paint that might be more appropriate?
28 Oct 2005
You've got to get all the grease off or nothing will stick to it.
4 Mar 2006
? the grease was on the top of the artex - which has all been stripped off - the surface was clean and dry!
21 Jan 2008
Angus
May have been too dry so all the moisture was sucked out of the filler and it didn't have a chance to stick.
I would chip out all the blown areas and check how absorbent the substrate is, if it soaks up water dead quick, its too dry, if it doesn't, its grease
If its the former, seal the plaster with a 1:5 PVA/water mix and then reapply the filler.
If its the latter, give it a good wash & rinse with sugar soap first.
