I have just replaced the old existing conventional boiler with a Biasi 32 Compact Combi boiler. Also have a hot water cylinder running off the boiler so we can have pumped hot water. It's fitted with a Siemens 3 port valve. The problem is the radiators downstairs don't get hot and the hot water cylinder and hot water from the taps gets far too hot. I have powerflushed the system and changed the downstairs radiators as someone suggested it could be a problem with sludge/blockage. I have also bled all the radiators and balanced them. This worked to a point but I had to turn the upstairs radiators down so low from the lock valve that all the radiators were barely warm. I have also replaced the 3 port valve for a new one as it seemed the hot water for the radiators is by-passing this valve and instead of going downstairs is filling the hot water cylinder instead. Even with the thermostat on the tank turned down to zero, the hot water cylinder is still too hot to touch and the hot water too hot to put your hand under. Could this be a wiring issue? Help, Help, baby on the way in two weeks and having a breakdown! Thanks
