Contemplating converting to sealed system on 30kW Kingfisher - I want to fit the PRV and expansion vessel at a distance of 3.5 metres above the boiler, connected by 22mm vertical pipe that tees directly off the 28mm flow pipe just after it comes out from the boiler but before the pump.
Filling loop will be connected to the return.
Is this close enough to the boiler to be 'safe'?
