Puma puma puma
Sorry Guys
have got a little problem with the central heating isolating cocks-flow & return - both have got a little leak -drip drip.
I have turned the preasure relief valve to relive water preasure in system, which for the moment has stopped the leak - no presure now, but alas if I presureize the system the drips start again.
The leaks are from the isolating cock taps themselves, which occurred after I had tried to turn them off - with minimal presure, while doing a seperate unrelated job.
I presume that these are normal cut off type valves ie turn clockwise for off and reverse for on!! , but they are not budging at the moment - may be clogged up with limescale etc?? . I don't want to put too much force on them or will I have to replace them anyway.
Many thanks in advance.
Edd1e
Sorry Guys
Edd1e
