Ok, I tried to ask this before - I'm now off the tablets so hopefully I'm more coherent!
I have a friend who want to pump his hot water.
He has a pump which can be installed at his hot water cylinder.
The current pipework is gravity fed.
If he just pumps it as it stands, He'll **** water out through the vent in the loft, back into the supply tank.
So... is there a gizmo to put at the top of the pipework to seal the system [from pump to vent & all the hot taps inbetween] but allow trapped air out.
This is assuming that allowing the feed tank to 'take back' any expansion in the cylinder, is acceptable?
I kinda know there maybe a suitable automatic airvent where there is little or no pressure but will it work ok under 1.5bar pressure?
Is this an acceptable solution?
