Pumps wiring on a S plan ?
12 Jan 2008
Essex
Got to assist finding a fault next week on some pumps that have no power
It is a big building it has a big boiler ,and a big immersion tank
There are two straight honeywell valves and two smallpumps,
as well as a bigger pump by the imm tank.
Should I swat up on an s plan diagram,
What would be the function of the 3 pumps be, and will they be linked to work with the honeywell valves.
There is also another small boiler and just a pump, possibly for one of the floors,
Would that pump run permenently
Is there a basic procedure to check these valves and there outputs
I am still looking for a nice book to try to learn some of it
Many thanks
Just stick to carrying his tools and assisting!!
Its to be hoped your colleague is more experienced!! :lol:
You are out of your depth here.
Dave
Yes I agree , we have been asked to look though and have no option, as the So called Heating engineers, Cannot do it, and for some reason five of them.
And say there is a cable fault ,
although they cannot tell us how or where the wires might go,
We can follow the cable through two floors ,which we will do,
but with an idea we could just check point to point.
And confirm to the heating engineers the result
I used to remember often the faults were the valves seized and the contacts not working, but its been a while and want to read up on it
It was here on this site , that I was told most learn the wiring side, through experience, so I need to start somewhere.
We are electricians and agree we dont know, all the pipework etc .
Big building with big boilers require big boys.
If you don't know what does what don't bother because you can do a lot of damage, including splitting the boiler, and that would cost you a years wages at least.
Does the big immersion tank look anything like THIS? i.e not a conventional foam covered cylinder.
If so it is a Thermal Store system and your clients need a heating engineer who understands them. The makers of the cylinder would be the best people to advise on who to use.
Info about how thermal store systems work can be read HERE
Thanks, for the confidence.
1st Pump traced back to panel (no Drawings) next to heating panel, contactor controlled by boiler pump output, no supply out to pump, due to one pole of three pole contactor open circuit. :o
2nd pump traced back to same panel, contactor supplied from valve aux output, fed from data box output controlled by electronic stat,no supply to pump due to previous heating engineer removing contactor pump supply fuse thinking it was a redundant panel, to try to fix his heating panel. :o
All cables tested correct fuses fitted etc
All pumps now working as before
Just waiting for the boiler to be serviced by a corgi eng :) :roll:
One wonders why five days have passed!
When I used to do commercial gas callouts they wanted me there within two hours ???
Tony
I am not having a dig ,just updating how I got on.
It was not one of our clients and there was concerns about payment ,we do electrical , and do not normally get involved with heating,we went to help out at our convenience , which was yesterday.
As he alledgedly had problems getting a heating firm to do it.
Personally think it was coz of his attitude as he was an utter a******e
The pumps had been off for three weeks and, there was no heating to half the premises anyway.
