RAD not working
13 Oct 2003
Hi All,
I was wondering if everyone can help us with this 2 problem we facing.
We have a combi boiler in our house and recently we had a small leak in the boiler one of the nuts was slightly loose, this problem is now fixed.
However, the pressure was down due to this leak and we had to refill the system. Now the pressure level has reached over the 3 bar and the boiler is making a laud noise.I thought by bleeding the RAD will lower the pressure but all the RAD are full of water i.e No air comes out.
Is there any other way I can lower the pressure?
2nd problem we have is with 2 RAD. Each time we put the system on it only gets warm. Again I tired to bleed the RAD's but no air comes out, just water comes out straight away.
Appreciate if can help us.
Many Thanks,
Miah
Turn off your boiler and attach a hose to one of your drain off valves downstairs. Undo valve which will empty your system until your pressure reaches 1 bar on the guage.
With regard to your rad you will need to balance your system by shutting down some rads via the locksheild valve and opening up yours until they all heat up properly.
Do a search on balancing if you run into problems :D
Thanks BAHCO
1 question. Do I close the lockshield valve only on the effected RAD or do I need to do this to all RAD’s and then open it 4 turns?
If you close the rad you will get no heat into your rad :oops:
Balancing rads means you apply resistance to rads (by closing the valve down) so that the hotter ones getting more flow need to be open less.
Obviously the colder ones need to be open more. :D
make sure the fill loop is closed and disconnected :)
Thanks for your help.
I managed to lower the pressure of my boiler last night. However as for the Rad's I turned the TRV around and back this seems to have worked but not completely. The Rads gets very hot for approx 1 hour then it gets warmer and warmer, but rest of the Rad are very hot.
Could this be balancing issue or something else?
Many thanks
Miah
Yes, they need to be balanced as my previous reply.
The ones nearest the boiler need turning nearly closed and the others need to be more open :D
As for the upstairs RAD do I close the nearest hot RAD and do the same?
