radiator in the way of my wallpapering!!!
26 Jun 2005
London
hello plumbers
I want to take a radiator off the wall to wallpaper behind it. How do i do this?
I have a potterton puma cobi boiler.
thanks
yes indeed greetings.
close the valves on your rad and empty the rad by undoing a nut on the valve...the one nearest to the rad...this will allow the water to drain from the rad in to something ? a pan, a bucket etc...what ever u can under it.
once empty undo the other side and take it off the wall.
I will get my hubby on to that right away.
I knew it could'nt be to difficult. great forum.
thanks
put a towel below each rad valve, close the valves. then crak the connections and try to lift your rad off the brackets. you will then be abl to lower it to the floof still connected. tighten the connections to stop any water escaping and paper to your hearts content :P
this is the cheaters way of doing it, so i take no responsibility if it goes (.)(.)'s up............... :evil:
