    Dismiss Notice
Radiator not projecting any heat
Discussion in 'Plumbing and Central Heating' started by k4renm4c, 9 Aug 2011.
  1. k4renm4c
    k4renm4c
    9 Aug 2011
    3
    Thanks Received:
    Glasgow
    Country:
    Although it is one of the biggest in the house and gets hot to touch all over (no air) you never feel any heat off it when you walk into the room in winter. Other rooms you can tell the rad is on, but this one barely makes a difference. We now have a damp/condensation prob because there is never any heat to the room.
    However it does feel hot to touch and is a large rad. The same size and model work well in other rooms so why not this room. I bleed them twice a winter or as required. The gas boiler is serviced annually.
    Suggestions welcomed!!
    Karen
  2. Sponsored Links
  3. bewsh
    bewsh
    9 Aug 2011
    2
    Thanks Received:
    Cardiff
    Country:
    possibly the rad is undersized, meaning the room loses more heat than the radiator can give out.
  4. The831Bunny
    The831Bunny
    18 Mar 2008
    1,459
    Thanks Received:
    967
    Country:
    Check the fins at the back of the panels top and bottom for fluff/pet hair etc.
    A radiator atcually only radiates 20% of its heat, the rest is convected. Has it got a thermostatic valve? Sometimes they stick and restrict flow through the rad. But as bewsh said, its possible its undersized if its hot all over.
  5. Armo74
    Armo74
    12 Apr 2010
    1,038
    Thanks Received:
    200
    Derbyshire
    Country:
    Is it on an outside wall? Do you have cavity wall insulation?
    Is it a recent problem if not when did you notice it?
  6. xr4x4
    xr4x4
    1 Oct 2009
    3,159
    Thanks Received:
    290
    Hampshire
    Country:
    This may sound odd, but has the rad been painted?
  7. Nige F
    Nige F
    28 Jun 2005
    21,204
    Thanks Received:
    1,741
    Country:
    particularly silver :idea:
  8. k4renm4c
    k4renm4c
    9 Aug 2011
    3
    Thanks Received:
    Glasgow
    Country:
    Cheers guys.
    I just measured it - its 90x22'' in a room that is approx 12ft x 12ft with a large triple bay window on the opp wall. Its on an internal wall, immediately behind is a cupboard and next to the cupboard is the boiler room. It is painted magnolia (by previous owner) but they are all painted the same throughout house and others work fine. It has one of the control knobs (1-5) but I always put it on 5 as it can be so cold. I tried all the numbers tho just in case it was an alignment issue or something.
    It has always happened since I moved in 5 years ago. The previous owner thought he was a plumber/central heating whizz, so much so that he plumbed the toilet into the hot tap. My poor mother let out a yelp the first day I moved in :D
    It wasnt a big deal until I decided to rent the house out. The last tennants moved out because it was too cold and damp in this room (the master bedroom). I have to agree as it was always the coldest room in the house when I lived here. Time to fix it before the new tennants arrive.
    New big, cosy radiator?
  9. expertgasman
    expertgasman
    16 Aug 2010
    2,161
    Thanks Received:
    276
    Cleveland
    Country:
    I had that in France, the Dordogne, if I recall correctly. Very pleasant, with a nice Merlot. Fricassed F@nny. :)
  10. Sponsored Links
  11. doitall
    doitall
    8 Jan 2005
    19,003
    Thanks Received:
    1,538
    Bath
    Country:
    So what is the temperature of the radiator, and does it have fins (convector's) below 60c and you could have the answer.
  12. misterdubya
    misterdubya
    2 Oct 2010
    3,625
    Thanks Received:
    539
    Country:
    And you thought it was her who was having hot flushes :)
  13. D_Hailsham
    D_Hailsham
    18 Oct 2007
    10,587
    Thanks Received:
    1,343
    Kent
    Country:
    The rad may feel hot to touch, but is it giving off any heat? If it is, the temperature of the water leaving the rad will be lower than when it entered. You have to adjust the flow through the rad so the water has time to give off heat.
    Check, by feeling, the temperature of the two pipes connected to the rad; one should be cooler than the other. Compare this to other rads. If there is very little difference in temperature, the rad has not been balanced properly. This could mean the whole system has not been balanced.
    You balance by adjusting the lockshield valve - that's the one under a cylindrical cover. Read How to balance a CH system
    • Thanks Thanks x 1
  14. dcawkwell
    dcawkwell
    2 Nov 2010
    3,422
    Thanks Received:
    516
    Humberside
    Country:
    Put a new radiator in on the outside wall.
    Double panel, Double convector. It will be roasting in no time.
    Job done.
    Rooms never feel warm without the radiator under the window
    especially when the wind blows directly at the window like
    it does in my house. It's freezing.
  15. gasafengineer
    gasafengineer
    23 May 2011
    314
    Thanks Received:
    34
    Wigtownshire
    Country:
    If emitter is not balanced correctly you will 'usually' notice flow into emitter would be @ boiler flow temp with return out of emitter being stone cold , if you find little temp difference between flow/return (10k) @ all emitters then this will indicate system is balanced correctly. ;)
  16. D_Hailsham
    D_Hailsham
    18 Oct 2007
    10,587
    Thanks Received:
    1,343
    Kent
    Country:
    The only way you would get a stone cold return is if the LS valve was completely shut. Even a quarter turn open will give a warm pipe. The working range of a typical LS valve is from closed to 1½ turns open.
    It all depends on what you mean by "little"! You should be able to feel a 10k difference. That's why I suggested comparing it with the others.
  17. gasafengineer
    gasafengineer
    23 May 2011
    314
    Thanks Received:
    34
    Wigtownshire
    Country:
    Nope...............unless of course i've been seeing (feeling :mrgreen: ) things for the last 35 odd years.....................same applies with sticking TRVs , flow entry is hot wherby return is stone cold , lack of water flow rate being the issue here......................go crack a lockshield open & see.
Loading...
Share This Page
