have just removed 3 rads from my front room and i'm sure the sizes are imperial as the new rads are upto 80cm too small.i have used adjustable tails but they just look naff and a bit of a bodge job.the largest rad is 1600mm and this is too small with the tails and valves connected.even if i used radiator covers i could not use the trv's as these will be in the cabinet.also the pipes are set in a concrete floor and at different angles/distance from wall etc......
I have spent alot of time and money on the room (plasterer,electrician,paint etc) and i don't want to end up looking at mismatched radiators.the rads i have bought are the closest to the distance between the pipes,slightly too small rarther than too big.
any suggestions please.
