I had a new condensing boiler installed in January. Radiators took a long time to reach proper temperature after installation but plumber thought it might be something to do with pipes being too small, even though I had no problems with old boiler. So I thought maybe a pump problem. I removed the middle brass screw, went to turn the middle screw, but all of a sudden the screw sprang backwards and the water started pouring out. So I just put the brass screw back in again. Had another look yesterday but cant get to the middle screw as too much water pouring out all the time. The pump is not new, no idea how old it is. Its a Wilo Salmon pump. All radiators have been balanced apparently. One radiator in the living room does get very hot quicker than any of the others but this is a new radiator. The other radiator on landing, hall, and living room take 3 hours to get to really hot. Bedroom rads get hot in about an hour. Why doesnt the hall, landing and the other living room ones come up faster? Ive bleed them all and took one off to get it cleaned out. The landing rad was fine before I removed the thermostat valve recently to a normal valve (thermo valve kept getting stuck). Any ideas?
