Hi All,
I have a Ravenheat 820 combi boiler I inherited with the house we bought about 6 months ago. I would like to install a room stat (standard manual will be fine), but I'm confused about what exactly I need to buy.
Reading this thread;
http://www.diynot.com/forums/viewtopic.php?p=425531&sid=b6019b9d91af370d5d71be848bd13b1e
I can see that there are two connectors, I've located these in my boiler, that bit is OK.
What sort of stat do I need to connect to this, and does it need a separate mains feed?
I've seen a Drayton RTS8 at B&Q which claims to fit all combi boilers, is this the case?
Do I simply run a single 2-core wire connecting the two poles at the boiler to the 2 poles on the stat?
Thanks in advance
Thanks in advance
