    Dismiss Notice
ravenheat condensing combi 85t
Discussion in 'Plumbing and Central Heating' started by dave33plumb, 4 Feb 2011.
  1. dave33plumb
    dave33plumb
    4 Feb 2011
    3
    Thanks Received:
    Country:
    boiler runs on its own then overheats and starts ketling then cuts out this hapens when on hot water only runs fine on htg no probs need some pointers boiler had leaks prior to this they where fixed then this started
  2. combispecialist
    combispecialist
    4 Mar 2010
    271
    Thanks Received:
    35
    Lincolnshire
    Country:
    the only honest pointer i can give u is the scrap heap...failing that get it on a bg service contract cos this heap will carry on breaking down year after year :rolleyes:
  3. Sponsored Links
  4. Foobix
    Foobix
    20 Apr 2008
    42
    Thanks Received:
    8
    Stirlingshire
    Country:
    It would appear there is a restriction between the plate and main heat exchangers.Maybe the divertor is stuck or the plate heat exchanger is blocked.
    • Thanks Thanks x 1
  5. transam
    transam
    20 Nov 2009
    31,269
    Thanks Received:
    3,708
    Surrey
    Country:
    Most likely a faulty DHW ntc sensor (?) boiler will still provide hot water but will not modulate . noisey , ketteling , eventuall high limit lock out probably , ch is under control of another sensor !
    Ravenheat csi = condensing system innovation , the worlds only (?) A rated atmospheric condensing boiler ???
  6. Sponsored Links
  7. PEDANTICVINDICTIVEMAN
    10 Jul 2004
    13,014
    Thanks Received:
    2,714
    Country:
    Think it was one of these that I had to scrap at 3 years old fitted by warmfront, 10 leaks all Ravenheats, crossed thread on diverer from new and blown pcb, bag of ****e.
  8. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
