Ravenheat CSI85 no Central Heating or Hot Water
16 Jan 2008
Yorkshire
Hi
I have a ravenheat CSI85 4 years old, has separate ignition board and main PCB.
The pressure dropped due I think to a small leak, after re filling the system the boiler will not re start. The pump runs, the light is on, the pressure at 1.5 but no pilot or gas burner lights. Any Ideas???
Many Thanks
Tim
The timer is currently on the ON setting. How do you reset it? If the timer says ON how is it affecting the running of the boiler.
Tim
Did the boiler stop working BEFORE you repressurised it?
Have you found and cured the leak?
Tony
Hi Tony
I woke up one morning last week and pump was running but the heat not, Pressure was low, I found leaks and fixed them. Re-pressurized system and it will not re-start.
Tim
Don't know if you are still struggling with this 5 days on but if you are have you found the reset button? It is behind a screw off cap on your control panel.
After that try a pcb reset by turning to off position waiting a while and turning back on again.
Low water pressure switch could be blocked or faulty but it might be best to leave that one for an RGI
