I fitted a ravenheat LS80 combi boiler in march this year, it seemed to work ok although the gas would not modulate as the hot water flow was reduced. Then after about a month it would more often than not refuse to ignite, the relays clicked in & out rapidly, very often the fan would not start & if it did start the boiler would usually shut down at the point when the burner should ignite. I have changed the main pcb and this made little difference. However a week ago the thing decided to start working again but the boiler still will not modulate the gas and the hot water temp is down, adjusting the pot on the pcb makes no difference. Any ideas?
