    Dismiss Notice
Ravenheat water too hot.
Discussion in 'Plumbing and Central Heating' started by PJfixit, 14 Aug 2014.
  1. PJfixit
    PJfixit
    14 Aug 2014
    10
    Thanks Received:
    Country:
    Hi this is my first post so greetings to all.
    I have a Raven-heat csi 85t, :( it is getting old but has provided many years of good service.
    The problem is that there is no control over the hot water temperature.
    Once the hot tap is turned on the temperature of the water increases until it reaches scalding point.
    At the moment it is set to water only. I have changed both thermistors but this has not helped. I put a meter on the hot water potentiometer & the resistance changed as I turned it so I assume that is not the problem.
    By the way I am not a heating engineer.
    Any ideas what to try next? Thanks in anticipation.
  2. Sponsored Links
  3. pallen5000
    pallen5000
    11 Oct 2008
    265
    Thanks Received:
    87
    Nottinghamshire
    Country:
    Does the gas pressure modulate down?
  4. PJfixit
    PJfixit
    14 Aug 2014
    10
    Thanks Received:
    Country:
    Yes, goes up & down with the hot water potentiometer
  5. Dan Robinson
    Dan Robinson
    1 Jul 2007
    56,034
    Thanks Received:
    9,420
    Hertfordshire & London
    Country:
    [​IMG]
    There's a reason we call them Ravenheap.
  6. PJfixit
    PJfixit
    14 Aug 2014
    10
    Thanks Received:
    Country:
    Thanks Dan but I'm not quite sure how that helps me!
  7. onlyfitidealboilers
    onlyfitidealboilers
    11 Jan 2010
    2,041
    Thanks Received:
    155
    Aberdeen
    Country:
    So when you turn it to minimum it's still to hot?
    You may want to measure to temp diff of the cold water and hot water bearing in mind that you should have 35c above the specific flow rate?
  8. PJfixit
    PJfixit
    14 Aug 2014
    10
    Thanks Received:
    Country:
    I do not have a thermometer to check the difference. What I can say is that regardless of how the temperature is set the hot water coming out of the tap seems to get hotter until it reaches scalding temp.
    This seems odd as the burner can be seen to change with the temp. control knob. It must make some difference to the temperature of the DHW but even at its lowest it is too hot.
  9. onlyfitidealboilers
    onlyfitidealboilers
    11 Jan 2010
    2,041
    Thanks Received:
    155
    Aberdeen
    Country:
    How fast are you running the tap. Remember the slower you run it the hotter the water will be. If you have replaced the thermistors. How do you know your burner pressure is not to high? I've seen it many times where the voltage drops on the modureg but the burner pressure does not alter. My advise now is contact a gas engineer to inspect test and repair this unit.
    Regards
  10. Sponsored Links
  11. Agile
    Agile
    26 Jun 2004
    64,020
    Thanks Received:
    4,591
    London
    Country:
    He has already told us the gas pressure modulates. Hopefully as evidenced by the flame varying in size.
    My expectation is that he has a very low flow rate. We need to know the flow rate in litres per minute!
    And that a boiler fault is preventing the boiler turning off the flame when the water is too hot. Thats usually a PCB fault.
    But part of the diagnostic procedure is to measure the gas valve parameters. That will need a gas reg engineer.
    Tony
  12. PJfixit
    PJfixit
    14 Aug 2014
    10
    Thanks Received:
    Country:
    I am haring what you both say & yes I have watched the flame height to assess the gas valve modulation.
    I can soon check the flow rate if that helps. We do have fairly naff water pressure but that has been consistent for years whereas the water temp. Issue is more recent.
    Just to confirm I have had the tap full on but still too hot(low pressure does not help, usually about 1.5 bar)
  13. Agile
    Agile
    26 Jun 2004
    64,020
    Thanks Received:
    4,591
    London
    Country:
    The flow rate is about 11 li/min.
    If the gas valve settings are correct then the boiler will only modulate to about 1/3 which means any less than 3.3 li/min will get too hot and the PCB should turn off the gas supply to prevent this but this aspect does not seem to be happening.
    Usually a PCB fault but part of the diagnostic process is to check the gas valve settings. That needs an RGI.
    Tony
    • Thanks Thanks x 1
  14. PJfixit
    PJfixit
    14 Aug 2014
    10
    Thanks Received:
    Country:
    I think it is time to check the flow rate, I will do this & let you know the result.
  15. PJfixit
    PJfixit
    14 Aug 2014
    10
    Thanks Received:
    Country:
    Just checked flow from hot tap & we are getting 10l/min.
    I am wondering about the merits of changing the PCB as this will be considerably cheaper than calling an engineer out.
    Any thoughts?
  16. onlyfitidealboilers
    onlyfitidealboilers
    11 Jan 2010
    2,041
    Thanks Received:
    155
    Aberdeen
    Country:
    Not sure now tbh. I'd not like to guess this seems very odd, if your flow rate is right and it's modulation is working!
    It's up to you but I'd look for an engineer that charged a call out fee but an no fix no fee policy.
    • Thanks Thanks x 1
  17. PJfixit
    PJfixit
    14 Aug 2014
    10
    Thanks Received:
    Country:
    You may well be right but I have found a PCB for a good price.
    I will change it over & let you know the result, hopefully in a few days from now.
    Thanks again.
Loading...
Share This Page
