RCBOs
15 Dec 2008
Lancashire
Planning to replace the 4 6amp MCBs for lighting circuits with RCBOs to bring the installation into line with 17th edition
my question concerns the small flying lead earth 'reference' wires on each RCBO
should they be located each one into the respective position on the earth bar with the CPC for that circuit or can they be grouped together into one of the unused main earth positions on the bar
resason for asking this is the stranded reference wire is quite small and thin and may be prone to snapping or falling out if inserted with solid core CPCs, in my opinion they would be better twisted together and connected into a terminal of their own.
what is the best practice
btw the RCBOs are 'steeple' type b from denmans
Twisting them together isn't smart from a remove / replace point of view.
I terminate them in the earth bar position associated with the circuit. The wire is stranded and unlikely to break or snap due to tension from solid cpc cores.
Do you have access to the appropriate equipment to test the RCBOs and circuits after?
