Recommend me a 35mm to 42mm plastic pipe cutter
27 Jan 2011
UK
I have a no- name cheap pair of shears that drive me nuts - it depresses the pipe before it can locate the correct notch on the ratchet then when i do get it to start cutting it will not cut square I usually end up starting the cut and then stop squeezing and just turn the pipe.
So I have had enough and want a new cutter :cool:
I got the old black rothenburger plasticutters which are very good, not so sure about the new combined ones from the mixed reviews.
Yes I have had a look and they do not seem that good and people also comment on the older black ones being better but discontinued
Ridgid are a large American pipe tool manufacturer
Make some of the best pipe tools available but at a price!
There lifetime warranty really means what it says.
A lot of rothenberger hand toola are ridgid 'copies '
Sorry I did not understand that. Is that plastic pipe cutters
No, but that was in response to
just an aside into them being a large us outfit
I've got this and it's excellent.
Thanks for the heads up.
That is just like the one I have that drives me mad. No way of knowing if it is just as bad
Buy cheap, buy twice... An occasional DIYer would just use a hacksaw. If you're doing this kind of stuff regularly enough to want a better tool, get one that actually works
