Hi I have a vailaint turbomax boiler was working on heating but the hot water stopped working. Have stripped down the diverter valve and replaced the diaphram which had a small split and was slight perished also reaplced seals etc. cleaned the heat exchanger too. as Had similar done a few years ago now
Re-topped the system back up but when you start up it runs for a little then blows off steam from the pressure relief valve ? Is there still air in the system have I not bled enough or have I done something wrong. any help please
