refill update on 24cdi(sorted)
29 Dec 2004
hey there people! found out why i could not fill system pressure on my b/w 24cdi it wasnt the filling key or the filling valve assembly, but when i took the assembly out only 5 min job! there was a build up of what i can only say as carbon it was solid and hard where the assembly connects to the inlet housing it was totally blocked so no water could get through. a little gentle poking and wohoo freed it water flowed out!! refitted the asembly and refilled problem sorted! hope this will be helpfull to any 1 with this problem!!
Be careful with the merry cries of self-congratualtion!
If you found black oxide sludge blocking the inlet, the same stuff is probably blocking other bits of the boiler more difficult to reach!!
I bet there's no inhibitor in your system!
Pity, that.
