Repair floor after pipes burried
15 Jun 2004
Norwich
Im about 2 have radiator pipes buried in concrete floor. I have dug the channel & the plumber is going to wrap the pipes.
I was thinking of mixing sand & cement & laying to within 2/3mm of the top.
The rest of the room has bitumen on the concrete, what should I be using to finish the concrete?
I am having an engineered wood floor laid, in a few months when its all dried out.
The bitumen might well be the dpc, I'd ask your local builders merchants for an equivalent product to paint the last few mm with. You can also get bituminous double sided tapes, if your pipe cuts are nice and narrow and the surface is dust free that stuff might bond well to the floor and bitumen on each side of the cut and will be flexible enough to to roller flat. You're going to bE putting an underlay under the floor anyway which should take out any minor limps
