my bathroom tap has developed a slight leak which is slowly getting worse. If it was a standard tap it would be easy to fix, but alas it's not, its very similar to one of these:
http://www.plumbtap.com/product/Axi_Monobloc_Basin_Mixer_4G3040_4G3040#
The leak is coming from the underneath the handle i.e. the bit you lift up to open and close the water flow. Can you just pull the handle off somehow to get to the source of the leak? If not how do you get to it? I'm hoping they are fixable as a new one is about £150!
Thanks.
Thanks.
