Replace Gainsborough10.5 deluxe shower
19 Sep 2013
Ayrshire
My shower needs replacing. Must I use gainsborough or can I use other makes. My shower is tiled around existing one.
Any make will be OK to replace it with. The biggest problem will be getting one where the water and wiring entries match up with your old unit. Tiles should go behind the shower not be cut around it.
If you find you're going to have to do cable and pipe re-routing and tiling anyway, consider installing a remote one, then you'll be free from ever having to do all that again.
