replaceing damaged floorboards
2 Oct 2004
hi
have to replace damaged floorboards 8ft and 5 ft lengths non standard size (t & g) . Timber yard able to machine suitable lengths/sizes (par ? )
and these are to screwed down .Any advice on screws sizes types and how many per length.
TIA
Inch and a half eights are best. One each side of the board for each joist they pass over. I use a drill bit that countersinks at the same time.
joe
joe
thankyou joe-90 and splinter .
Found a box of 2'' eights closest to recommended and used countersunk drill bit ( good tip) . I will try every other joist and ends of boards if i need to do this again ( every joist is very very secure :wink: ).
splinter said:
Ideally , Two and a half inch tens :)
As a rule, 1/3 thickness of timber then 2/3 into fixing.
e.g 10mm timber need 30mm length nail etc
done and made note of this for future reference :)
