Replacement Corrugated Roof Panels for Garage.
20 May 2006
Gloucestershire
Hi
Hope someone can help.
I have an pre fab garage possible 30 yrs old covered with what looks like corrugated asbesbos or cement fibre panels.
A lot of the panels are split and need replacing. Panels are approx 10' x 4'
The corrugated profile is quite wide - can you buy a large profile cement fibre roof panel or onduline one that would match the old profile??
If I can match the profile I could cover the complete roof rather than remove what could be asbestos and the problems that go with asbestos disposal.
Or how effective would a couple of coats of cold set bitumen painted over the complete surface to seal any cracks?? I think Wickes do a 25 litre drum of bitumen.
thanks in advance
Dave
To answer your first question, yes. Google eternit. They aren't cheap though. Trowel on roofing mastic would provide a short term repair for small cracks. Google flexacryl.
I think it's time for a new roof, will be cheaper in the long run.
Wickes do a nice Bitumen Corrugated Sheet in black or green in 2m length
I was considering using those panels from wickes but was concerned about the ability of the fixing they provide preventing water penetration, should they be coated with some type of mastic to ensure nothing gets through or are they fine on their own?
As long as you follow the instructions regarding overlap, and use the appropriate fixings (they have little plastic 'umbrellas' on top :D ) then it should be completely watertight.
yeah I've seen those little umbrella thingies...sounds good,my garage will have a pitch roof(hopefully) made up of trusses then some 18mm ext ply,then the roof panels(or was gonna use a good quality felt) can I still use those wickes panels? what do I put at the front and rear edge,is there some kind of 90 degree edging trim available?
Use this for the top ridge and the bottom of the sheet overlap on the gutter
Thanks everyone
Looks like I will use the eternit roof panels over top of the old ones....
You are right though they are not cheap!!
thanks for all the advice
Ziggy
