I am about to replace a single oven. The present on is wired into a 20A cooker switch.
The spec of the new one is Maximum electrical power...3550W
I also says it should be protected by a 20A fuse
It goes on to say that the connecting cable should be H05 RR-F type cable or PVC twin and earth with a minium cross-section of 6mm^2.
I was going to replace the cable for the new oven but according to your "choosing the correct cable size section" this seems much overrated for this oven.
I would be interested in any comments ie must I use 6mm^2 cable?
Any help much appreciated.
