I have had a new shower installed in a flat I rent out. The replacement was organised by the letting agent with a NICEIC electrician. As i understand it the shower was replaced only and the existing cable (6mm2) used.
I have been struggling to get a minor works test certificate for this work. Can I just check whether this should have been done for this replacement shower unit or not. I want proof that the new shower is compatible with the cable size, MCB etc,
