Would like your advice on our situation:
We live in a townhouse which currently has 3 floors, soon to be 4 with a new loft extension (ground + 3) that is planned. The plumbing system we currently have is as follows.
- Boiler in kitchen (on ground floor)
- Cold Tank in current loft
- Hot Cylinder + pump on 2nd Floor (current top floor)
This system currently supplies 3 bathrooms, but we will be changing this to 4-5 ensuite. What system would you recommend to replace this with considering the tank in the loft will need to be removed? We would require adequate pressure at all shower heads.
I was thinking of making space for the cold tank in the new loft, and upgrading the current cylinder + pump to a higher capacity. Would this work?
