Agile said:
Replacing the CU requires a suitable qualified person and has to be notified to Building Control ( OR you can do it and call Building Control to inspect it before you power it! In practice BC dont have suitably qualified staff to inspect yet. )
No - it must be notified to BC
before you start any of the work. Interestingly, however, although the law itself gives a pretty good indication that this is notifiable work (but not an explicit one) if you were to go by the guidance on the ODPM website, which would be a pretty good defence if you ever got caught, there it says:
You do not need to tell
your local authority’s
Building Control Department
about:
repairs, replacements and
maintenance work; or
extra power points or lighting
points or other alterations to
existing circuits (except in a
kitchen or bathroom, or
outdoors).
So as long as the CU isn't in the kitchen or bathroom, replacing it, they say, is not notifiable...
Connecting the new CU tails to the sealed meter needs to be done by the electricity supplier ( at a charge ) and they will not do this unless you have a Certificate for the new installation ( or they inspect and Certify it for you at a further charge )
So leave their old tails in place, and don't involve them.
All in all I would not recommend this as a DIY job.
Unless there's an isolation switch, the service fuse needs to be pulled, which is not something that people should be advised to do. But apart from that, the simple act of replacing a CU is not very difficult. However, after the service fuse issue, the biggest hurdle is that if you are going to do it properly you should test all of the circuits before connecting them, and not many DIYers have access to the test equipment needed. The argument that the circuits will be in as good a shape as they were before is certainly true, but testing is what is required if you want to work to BS7671. Also, if you're adding an RCD where there wasn't one before it might be nice to have advance notice of potential earth faults...
Furthermore ensure anyone you engage is suitably qualified and can Certify the work and notify BC under one of the schemes. The best known scheme is operated by the NICEIC
FFS will you stop this NICEIC propaganda!
diywhynot - if you want to use a certified electrician, find a NAPIT member.
