Hello all - this is my first post on this forum - Glad to be here, hope someone can help.
I've seen similar posts, but I'm lacking a bit of clarification on whether earthing is required, and whether the existing wiring is up to scratch. We want to replace a single standard light fitting in the kitchen with 4 halogen downlighters.
The existing light fitting has only 2 wires - blue and red where they connect to the bulb, although black and red where the emerge into the ceiling rose ! The new downlighters say they are double insulated and should not be earthed.
I am planning on replacing the existing rose with a junction box, from where I will run 2 cables to the first two halogens, and then from them on to the remaining two halogens.
I was not going to worry about the lack of an earth lead, unless someone on here says differently ! Are there any other potential problems with this scheme that I should consider ?
,Peter.
,Peter.
