I'm attempting to restore an open fireplace in a 1940's brick/block semi.
The constructional hearth and back hearth are still in place. There is a liner in the chimney, but it is for an old gas fire/back boiler.
My intention is to have a simple fireplace with a firebasket on the back hearth. I'm going to remove the liner, replace flue cap with a chimney pot and install a decorative hearth made of slate. I will obviously have the chimney smoke tested and looked at before using the fire.
My question is this. . . the inside of the fireplace is brick and I want to render over it to protect the bricks and to make it look better.
Can anyone tell me what I should use to render it? Can I buy something specifically for it or do I need to make a mix and if so what ratios?
Thanks in advance!!
Maceman
Thanks in advance!!
Maceman
