R
ryanj
Finished rewire now, ScottishPower came early today and installed a new cut-out and the existing meter onto my board, I was instructed to install new 35mm2 tails between where the new service drop was to be and where he would install the cut-out and I left him a small 16mm2 earth tail from the earth block (don't want any bare strands for earth ).
He just removed the old tails and installed a new drop (interesting to watch), and connected by tails to the drop with some interesting looking connectors. Fortunately, there was already PME available on the line, so he didn't need to install any more rods.
Here's some pictures:-
Whole board. (1000mmx450mm).
The top of the fuse carrier was broken, so only the bottom one was sealed, but the seal is so loose, the fuse can be pulled out?
Existing meter, rated at 20-80amps.
New isolator, I installed.
Earth block, all 16mm2 to bonding.
Period Inspect and Report label
New consumer unit.
Questions:-
1. The meter is rated at 20-80amps, what does this actually mean?
That it won't register less than 20amps, or more than 80amps?
2. I got a rating of just under 0.15ohms for the Loop Imedannce (the prospective fault current was just under 4kA), is this about right, or should it be lower?
New consumer unit.
Questions:-
