Currently gutting a terraced house for my son and want to do a 1st fixing of ground floor sockets in front and rear rooms. Ground floor is solid floors with thick insulation and laminate flooring. The existing sockets are all surface boxes on skirting boards with cleats.
The fuse box (to be replaced by a new consumer unit) is in a fireplace alcove cupboard at floor level.
I'm trying to avoid the extra work of channelling the cables down the plaster from the floor above as there is insufficient sockets at present. Is it OK to run a 2.5mm ring main from the fuse box along the floor and knock metal back boxes into the walls 6" above the new skirting we will be fitting.
I'd like to lay the 2.5mm along the edge of the solid floor and channel into the plaster up to the back box, cover the cable with plastic trunking and plaster over. The think insulation and laminate will be going back down again so the cables will be under the edge of that and/or under the new skirting.
Will that pass inspection when the electrician checks it out ?
