Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
I want to fit a second valve on my rising main after the stop cock what is the best type to use ,would flow be restricted using the wrong one ,are ball valves any good?
You could ask at your merchants for a full bore isolation valve, you get these either with a screw slot or with a handle. As the name suggests full bore, without restriction.
