Roof Tiling queries on new build
9 Aug 2010
Hampshire
I'll shortly be tiling my single storey extention with standard sized clay tiles.
One corner of the roof is rounded off as you can see on the attached plan.It will also have bonnets if that helps.
I have tiled two gable ended roofs before but this is a bit more advanced.
Please can i have some advice on how to get the tiles around the bend (smoothly)?.
There is also a woodburning flue sticking up through the main roof .Whats the best way to make this opening solid and waterproof ?
Thank you
The bonnets are only for the hips and nothing to do with the curved section.
To do the curve you need to have the lath set out correctly, which itself will be diffficult. the tiles are then laid as usual but with mitred cuts to keep the joints between tiles looking tidy. You will also find the need to cut the width of the tiles to suit the side laps. It is very labour intensive. Personally I think with the skill needed you should use a professional roofer. Take a look at the example below and read how the lath were done as well.
http://www.dreadnought-tiles.co.uk/abbotts.htm
Also http://www.sandtoft.com/downloadfile.php?DataSchemeID=3&BLOBID=93 .pdf file on curved roofing
For the flue, I would do a traditional lead slate. I can do my own as I taught myself to do lead burning. You are best to have a local plumber make one up for you. The base should be around 600 x 600 so you can trim it to suit on site or maybe a little more depending on the diameter of the flue. (Give the plumber a section of Flue to get the sleeve the right size). Alternatively there are usually flashing kits with flue systems to deal with what you want.
