Rotex A1 Boiler BG24i/40i
Hp1
12 Dec 2005
Middlesex
Hi all,
I have to service a Rotex A1 boiler shortly. I have downloaded the manual from Rotex but this is not very informative.
If any one has serviced one of these German boiler I would be grateful if they could give me any tips. How and where do you carry out a flue gas analysis on this boiler (is there access points in the flue as per normal). The manual mentions a chapter on maintenance/cleaning, Is this all that is required on this model.
Many Thanks
Harry (Corgi Registered)
26 Jun 2004
London
Rotex A1 is a nice modern pre mix burner condensing boiler.
You should have no problems but make sure that your flue gas analyser battery is charged up before you go out.
Tony
Hp1
12 Dec 2005
Middlesex
Hi Tony,
Thanks for your reply. Have you worked on one of these boilers? Does it have flue gas analysis points on the flue outlet in the vicinity of the boiler (the manual does not give much away).
Once again thank you for your help.
Harry
26 Jun 2004
London
There are so few in the UK and they are so reliable that I have not had the pleasure of working on one yet.
They are quality products and I am sure you will find it has suitable test points.
Tony
Hp1
12 Dec 2005
Middlesex
Hi Tony,
Serviced the Rotex A1 BG25i boiler. It was a pleasure to work on, very well designed.
There is a Flue Gas Analyser point on the flue elbow under the boiler. however my Telegan analyser probe would not go in deep enough to obtain a reading. In the end I had to place the flue analyer at the flue outlet.
Once again thanks for your help (the Rotex technical guy was also very helpful). It is good that engineers with as much experience as yourself are prepared to help other that are still gaining experience.
Harry
